Tires MFWD One-Sided Tire Wear
   / MFWD One-Sided Tire Wear #1
greentractorman
One front tire on my JD655 MFWD is wearing more around the outside than the inside circumference. The tires are original equipment Good Year Softrac that have six rows of tread across the width of the tire. The outside two rows are worn almost too the cord. Only the outline of the tread is visible on the center two rows. The innermost row has about l/8th of an inch of tread. The tread is barely showing on the other front tire but is worn down evenly across and around the entire tire. The JD dealer seems to think (without viewing the tires) that the uneven wear on the one tire is due to the tires being badly worn (which they obviously are). My question is if so, then why only one tire and not both? In any event they need to be replaced now but before I do, I want to make sure I don't have a problem that will cause my new tires (well, at least one) to wear abnormally. I've eyeballed the axle/wheel assemblies and it appears that the only adjustable item is the tie rods. Any suggestions on trouble shooting techniques to determine if I really do have a problem (other than worn out tires) and if so how I go about correcting it.
   / MFWD One-Sided Tire Wear #2
Greentractorman
If the other front tire is not worn the same way your toe in (that would be the tie rod adjustment) is probably ok. The only other thing would be the camber which is the top of the tire leaning in or out. Out if it is worn on the outside. If you don't have a way to gauge this eye balling it should be close enough for a tractor. (make sure both tires have the same amount of air and are the same diameter first) Chances are it is just a defective tire. Sometimes a tire will break one or more belts which will alow that part of the tire expand and wear more. Possibly softer rubber on that part of tire. Good Luck
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
