MfF 65 3 pt hitch
   / MfF 65 3 pt hitch #1
fatb
Massey Ferguson 65 Gas
New to tractoring and recently bought a new old tractor '58 mf 65, just wondering if I need to add a top link bracket/beam to use top link and do i need to buy a braket for chain stays for control arms?
   / MfF 65 3 pt hitch #2
At the bottom red circle it appears that pin is in backwards. Face it the other way.
The red circle on the left. You may be able to fit a pin in there and then use an arm similar to a top link to connect the 2.
That will adjust your control arms.
My Massey came with a bracket that attached to the bolts in the left circle. That is there my control arm connects.
Can add a picture this evening.
As for the top blue circle.
If you can fit the end of a top link in there you can use your top link as is.
   / MfF 65 3 pt hitch
I just bought some check chains, check chain brackets, and control beam. I will also purchase a top link. thanks for the info
   / MfF 65 3 pt hitch #4
Attached (hopefully) 08128FE4-BBFB-4022-AFE7-BB58658BC3BB.jpeg1106F72C-2C2E-42E8-AA9C-459211691CC3.jpegare h08128FE4-BBFB-4022-AFE7-BB58658BC3BB.jpeg1106F72C-2C2E-42E8-AA9C-459211691CC3.jpeg
   / MfF 65 3 pt hitch
oh ok those are stabilizer bars right?
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Homemade Flatbed T/A Tilt Trailer (A50323)
Homemade Flatbed...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
