MF65 IP removal
/ MF65 IP removal #1
dkarten
I have confirmed my IP is bad & am in the process of removing it, I have the timing cover removed, the timing gear removed, & 2 1/2" bolts removed, the third bolt is between the IP & the engine, very hard to get to but worse than that, it does not seem to be a 1/2" hex bolt, it might be an Allen but impossible to see, anyone BTDT?
/ MF65 IP removal #2
I'm fairly sure your reference to IP is not Internet Provider, And probably not Instrument Panel. So what is it?
and BTW I'm very familiar with MF65's... KennyV
/ MF65 IP removal
Injection Pump, I had posted previously while trying to determine if that was the problem
/ MF65 IP removal #5
Injector pump... alright ... I have beem dealing with several IP's Internet Providers this wk... but no injector pumps.
Can't help much in the removal, but while you have it off and in for an evaluation take the injectors in for the same... KennyV
/ MF65 IP removal #6
The third bolt is usually the same as the first 2. I use a 3/8" ratchet with a 6" extension and a swivel socket. You have to make your combination just slightly longer than the pump and work the ratchet at the back end of the pump. I have a long Snap On flex head ratchet that I like to use. It is a tight fit, but this works for me.
Good Luck
Mike
/ MF65 IP removal
the 2 bolts I removed are 1/2 " hex heads, the 3rd one, behind the pump, is not a hex, someone must have replaced it, possibly with an Allen,
/ MF65 IP removal
I was able to determine that the 3rd bolt was a 7/32 allen & have removed the pump, I'm in the process of looking for a rebuilt IP & also need to replace the fuel line that goes from the secondary filter to the IP, unable to find any new part listing for that line & am looking for a used one, any suggestions?
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
(3) MILITARY CARGO BOXES (A64281)
(3) MILITARY CARGO...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 EZ-GO ELITE...
Generator on Trailer (A64119)
Generator on...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
