Oil & Fuel MF65 fuel lift pump identification
   / MF65 fuel lift pump identification #1
mf65ro
MF 65
I have a MF65 (english built 765) with Perkins AD4.203 engine.
Recently I changed the o'rings for stop and throttle into the injection pump. After that looking up into the lift pump bowl, with the engine idling, I can see some air bubbling. Also after I stop the engine and start it after some time I can see how the pump spits out oil (it seems that is mixed with diesel), which makes me believe that the diaphragm is compromised.
On the lift pump housing is written AC , Made in England , and under the pump body near one of the screws I can see 771 F4 . Can you help me to identify the serial number ?
Can you let me know if the DELPHI HFP138 will be a good replacement ?
Thank you all very much for your time,
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2025 AGT 750 (A50123)
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
