MF50B wonエt start, worked perfectly until yesterday, engine/motor trubble
   / MF50B wonエt start, worked perfectly until yesterday, engine/motor trubble #1
Makedonche
Sweden
Massey-Ferguson 50b
Hi!
I worked with my MF50B yesterday around my house, it worked perfectly until then, no strange engine noise or enything else...
I won?エt start now, i find out that the oil level was low....I usually check oil level before i start it, but somehow i forgot it...
After checking everything i find out that the motor is stuck, it do not turn around at all, i tryed turning it around behind the hydraulic pump and behind the starter without any big result, it moves a litte, little bit, I?エm not sure if i should try a little bit harder whitout making it worse...
How can i get it to turn around by my self, is it even possible now? whithout a complete rebuilt or sending it to the scrap yard...
Thankful for any idea!
   / MF50B wonエt start, worked perfectly until yesterday, engine/motor trubble #2
Can you be more specific please?
low oil. was any on the dipstick?
motor stuck. as in seized solid??? does the starter motor just go click , click, click? or is there no response at all from the starter motor?
   / MF50B wonエt start, worked perfectly until yesterday, engine/motor trubble #3
If you have a least a some cylinder movement it is not completely seized and should be repairable.
I would call the M-F distributor and make a repair appointment.
Until the engine is opened up we can only speculate from here.
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
