operatingengineer
- Joined
- Oct 9, 2024
- Messages
- 4
- Tractor
- 1962 MF50 diesel
Hey guys! new guy here! having a no start issue with my 1962 MF50, tractor ran fine when i parked it ,I don't use it much but 2 years ago my wife stopped planting a big garden, so it sat unstarted for 2 years with the shut off pulled out
and the pump had a slight leak
! so when I went to start it last week it cranked and had no fuel to the injectors, first thing i did was bleed the system and it gets great pressure to the pump bleeders, but just a tiny no pressure squirt out of the fitting to the injector lines! i took the top cover off the cav pump and everything was covered in varnish and the throttle valve was very stiff! got to be the problem! no biggie i figure i get a kit and some new filters,5 gallons of fresh fuel and because that pump sweated from a few seals anyway i order the parts! fast forward a week i install all the new filters remove pump disassemble clean and install all the new seals and gaskets, put it back on and still no real pressure out of the pump! i pulled the pump off 3 times now and watched 4 cav pump rebuild videos thinking maybe i missed something but i have triple checked everything and all seems to work normal and move freely! the pump pistons were also gummed up but are nice and clean now! this pump is super nice inside showing no signs of wear on anything so i hate to think of spending $700 for a rebuilt! do you guys have any thoughts on what would cause no high pressure?
