MF50 hydraulics
   / MF50 hydraulics #1
jwright
I just purchased a MF50 with loader and backhoe; the hydraulics on both of them run off of a PTO mounted pump.
The 3pt. hitch lift arms do not work; they do not seem to be connected in any way to the loader/backhoe hydraulics.
Do the 3pt. lift arms run from an internal pump ?
Moving the raise/lower lever does nothing.
   / MF50 hydraulics #2
Your 3pt Runs Off A "Ferguson" Pump Located In The Belly Of The Rear Trans. Housing, Depending On Hookups You Might Have A Selector Valve Somewhere That Would Direct Oil To Your 3pt & Another Implement, Check Under The Right Front Of The Seat On Top Of The Trans., If There Is A Block With Hoses Coming Out There Should Be A Switch To Activate The 3pt. If Not It Is Possible The Pump Needs A Rebuild, There Is A Pressure Test Port In The Same Location To Test Pump Pressure, I Can't Remember Exact But I Belive Around 2350 PSI.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
