MF399 transmission and PTO problems
   / MF399 transmission and PTO problems #1
roberth58
Shalimar, FL
LS U5030C / Ford 655C / MF399 / Cat D4E
I am trying to nurse a neglected 399 back to health. Its a 1990 2wd 12 speed syncromesh with IPTO. When cold the PTO will spin even when disengaged, you can't stop it by hand. After running for 4-5 minutes you can stop the PTO with your hand and it runs correctly when engaged and you can stop it by hand when disengaged. Since its not freewheeling when cold it seems to be more than a worn brake. The trans problem is a jerkiness or shuddering, the gear, range or time running does not seem to affect it. It drives like you are lightly stepping on the brakes at random every 1-10 seconds. I hope someone has some suggestions because the perkins runs like a sewing machine and I would hate to give up on her.
thanks
Bob
   / MF399 transmission and PTO problems #2
Would start to check the brakes, do you have the right oil on the transmission?
I changed hydraulic fluid and replaced the filters in case that was a problem. What can I check on the brakes?
thanks
   / MF399 transmission and PTO problems #4
What type of oil did you use?
2018 Nissan Sentra Passenger Car (A51694)
2018 Nissan Sentra...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
378808 (A51573)
378808 (A51573)
2018 FORD F-150 (A52472)
2018 FORD F-150...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
