MF399 transmission and PTO problems
   / MF399 transmission and PTO problems #1
roberth58
Shalimar, FL
LS U5030C / Ford 655C / MF399 / Cat D4E
I am trying to nurse a neglected 399 back to health. Its a 1990 2wd 12 speed syncromesh with IPTO. When cold the PTO will spin even when disengaged, you can't stop it by hand. After running for 4-5 minutes you can stop the PTO with your hand and it runs correctly when engaged and you can stop it by hand when disengaged. Since its not freewheeling when cold it seems to be more than a worn brake. The trans problem is a jerkiness or shuddering, the gear, range or time running does not seem to affect it. It drives like you are lightly stepping on the brakes at random every 1-10 seconds. I hope someone has some suggestions because the perkins runs like a sewing machine and I would hate to give up on her.
thanks
Bob
   / MF399 transmission and PTO problems #2
Would start to check the brakes, do you have the right oil on the transmission?
I changed hydraulic fluid and replaced the filters in case that was a problem. What can I check on the brakes?
thanks
   / MF399 transmission and PTO problems #4
What type of oil did you use?
Year: 2007 Make: Workhorse Custom Chassis Model: W22 Vehicle Type: Incomplete Vehicle Mileage: (A51694)
Year: 2007 Make...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
