Mf35 radiator, rod, tie?
   / Mf35 radiator, rod, tie? #1
Ewgoetz
Venice, fl
Massey ferguson
I pulled off the body on my mf35 today to try to figure out where exactly my engine oil is leaking from and to take car a coolant leak from the upper radiator hose. In the process I found I'm gonna have to replace the radiator after all like I originaly suspected a few months ago, and the radiator support rod was Mia.
Anyone know where I can find a new one? Been searching online for a few hours now with no success. Other option I see is if some one online has the dimensions of the rod and I can custom make it myself.
The rod I'm looking for is number 4 in the pic below. Thanks!
Also another question.....are there any modern spin on diesel filter kits out there that replace the cartridge diesel filters?
   / Mf35 radiator, rod, tie? #2
as far as the filter I bouht a kit off ebay for my 65 easy job and well worth the effort
You don't have any pics or numbers of it by chance?
   / Mf35 radiator, rod, tie? #4
just o to ebay type in massey 65 then just look for the filter and adapter about $ 18- $20 I just looked and it was the first add
   / Mf35 radiator, rod, tie? #5
The rod from my '55 TO-35 is 5/16 round stock. The bent legs are @ 9 3/8" apart and are drilled .100" for cotter pins. One leg is drilled at 3/8" and the other is longer at 5/8" from the edge of the long part.
Thanks ran!
CONTACT INFO (A53084)
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
1996 CHEVROLET CAPRICE SEDAN (A52576)
1996 CHEVROLET...
8065 (A51572)
8065 (A51572)
