MF35 Injector Pump Parts
   / MF35 Injector Pump Parts #1
docbar85
North Carolina
M.F. 231 and 35
I'm looking for somewhere to purchase parts, the parts I need is where the fuel enters the pump, I believe it maybe called the end plate. It has the filter, some springs and a couple of other components in it. I'm mainly looking for the springs because I'm not sure if one of them I'm using is the right one. I have had no luck finding someone who sells these items, plenty of diagrams with the part numbers but that's it.
   / MF35 Injector Pump Parts #2
Sure I can help.. Gonna need the pump # & the parts you need..
   / MF35 Injector Pump Parts #3
Theres 30 injection pump shops in NC.. any one of them would be happy to sell you parts..
Call'm up, give'm you pump # & tell'm what you need.. its easy.
Why are you in the endplate anyway??
   / MF35 Injector Pump Parts #4
Hi Docbar85,
I can help you. Few weeks ago I found some pumps here. You can go their. Hope you'll got great service from them and quality products.
Pump# 3230080. To make things simple I would like to get all the parts in the end cap, mainly the springs and filter.
   / MF35 Injector Pump Parts #6
IF you've taken the regulating sleeve out, there is a spring under it also..
4 springs total..
bottom/start spring is>7123-439
2 springs on top of piston>7123-033e & 7139-449a
Then the big spring that sits ontop of the regulating plug>7180-879a
The filter is>7123-620a
The oring on the inlet nut is>7185-815k
Just call your local fuel shop for parts. Good luck.
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
