MF35 Injector Pump Parts
   / MF35 Injector Pump Parts #1
docbar85
North Carolina
M.F. 231 and 35
I'm looking for somewhere to purchase parts, the parts I need is where the fuel enters the pump, I believe it maybe called the end plate. It has the filter, some springs and a couple of other components in it. I'm mainly looking for the springs because I'm not sure if one of them I'm using is the right one. I have had no luck finding someone who sells these items, plenty of diagrams with the part numbers but that's it.
   / MF35 Injector Pump Parts #2
Sure I can help.. Gonna need the pump # & the parts you need..
   / MF35 Injector Pump Parts #3
Theres 30 injection pump shops in NC.. any one of them would be happy to sell you parts..
Call'm up, give'm you pump # & tell'm what you need.. its easy.
Why are you in the endplate anyway??
   / MF35 Injector Pump Parts #4
Hi Docbar85,
I can help you. Few weeks ago I found some pumps here. You can go their. Hope you'll got great service from them and quality products.
Pump# 3230080. To make things simple I would like to get all the parts in the end cap, mainly the springs and filter.
   / MF35 Injector Pump Parts #6
IF you've taken the regulating sleeve out, there is a spring under it also..
4 springs total..
bottom/start spring is>7123-439
2 springs on top of piston>7123-033e & 7139-449a
Then the big spring that sits ontop of the regulating plug>7180-879a
The filter is>7123-620a
The oring on the inlet nut is>7185-815k
Just call your local fuel shop for parts. Good luck.
1988 Ford F-250 Pickup Truck, VIN # 1FTEF26N1JNA71750 (A51572)
1988 Ford F-250...
2023 JOHN DEERE 8R370 LOT NUMBER 201 (A53084)
2023 JOHN DEERE...
1036 (A51572)
1036 (A51572)
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
