MF35 Diesel Ignition Switch Wiring
   / MF35 Diesel Ignition Switch Wiring #1
whodattractor
Texas
mf 2135
I have a MF35 diesel with thermostart(intake manifold heater). The original switch was not wired and does not work. I got a new switch that has the same terminals but I don't know how to wire it. There is a position for off, start, heat, and heat start. However there are only three terminals. One terminal has two prongs. How do I wire this? Where does the feed from the ammeter go? IMG_4009.JPG
   / MF35 Diesel Ignition Switch Wiring #2
I will have a look at two here and see if I can help. :) Might be a day or two though. :rolleyes:
BTW, Best Wishes for Christmas and the New Year to all and their loved ones. :thumbsup:
   / MF35 Diesel Ignition Switch Wiring #3
Hey Patrick I got it, I ended up using a multimeter and tested for continuity. Merry Christmas!
   / MF35 Diesel Ignition Switch Wiring #5
Yeah, I was going to suggest that - a process of elimination with a meter, but being unaware of your level of expertise it could have potentially been confusing. Nevertheless, all's well. :thumbsup:
   / MF35 Diesel Ignition Switch Wiring #6
really wish you would have posted the answer to this problem. Having exact same issue can not figure out how to wire this. MF35 diesel with same switch.
378810 (A51572)
378810 (A51572)
2006 BIG TEX 25+5 GOOSENECK TRAILER (A52472)
2006 BIG TEX 25+5...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
