MF35 Diesel Ignition Switch Wiring
   / MF35 Diesel Ignition Switch Wiring #1
whodattractor
Texas
mf 2135
I have a MF35 diesel with thermostart(intake manifold heater). The original switch was not wired and does not work. I got a new switch that has the same terminals but I don't know how to wire it. There is a position for off, start, heat, and heat start. However there are only three terminals. One terminal has two prongs. How do I wire this? Where does the feed from the ammeter go? IMG_4009.JPG
   / MF35 Diesel Ignition Switch Wiring #2
I will have a look at two here and see if I can help. :) Might be a day or two though. :rolleyes:
BTW, Best Wishes for Christmas and the New Year to all and their loved ones. :thumbsup:
   / MF35 Diesel Ignition Switch Wiring #3
Hey Patrick I got it, I ended up using a multimeter and tested for continuity. Merry Christmas!
   / MF35 Diesel Ignition Switch Wiring #5
Yeah, I was going to suggest that - a process of elimination with a meter, but being unaware of your level of expertise it could have potentially been confusing. Nevertheless, all's well. :thumbsup:
   / MF35 Diesel Ignition Switch Wiring #6
really wish you would have posted the answer to this problem. Having exact same issue can not figure out how to wire this. MF35 diesel with same switch.
Genie GTH1056 (A50120)
Club Car Electric Golf Cart (A50121)
Club Car Electric...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
Set of Rubber Skidloader Tracks (A50774)
Set of Rubber...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
