MF35 cracked Hydraulic ram cylinder
   / MF35 cracked Hydraulic ram cylinder #1
Dabrowski
Melb, Australia
Massey Ferguson 35
hi guys,
well after completing an engine service after purchasing a MF35 I turned her over and noticed the lift arms were in the top position. I cant recall what levers I pushed next (either operational or draft) but I then heard a loud bang and found that one of the bolts under the lift cover had snapped :thumbdown:
I then lost all lift up and down. The lower linkage arms were basically hanging loose.
I managed to find a local mechanic to tackle the job and he sent me through the photos of the aftermath. looks like the ram cylinder is cracked and the piston has a big dent in it.
Question; Does anyone know what may have caused this? (When the bolt snapped I heard a loud pop and the bolt shot up on hit the bottom of the seat/chair)
IMG_20190121_202919.jpgResized_20190124_191126.jpegResized_20190124_191155.jpegResized_20190124_191323.jpegResized_20190124_191809.jpegResized_20190124_191839.jpeg
   / MF35 cracked Hydraulic ram cylinder #2
My first WAG would be your pressure relief valve is not working.
   / MF35 cracked Hydraulic ram cylinder #3
Hydraulics have to have a relief valve in the circuit to keep from dead heading.
Without relief valve or malfunctioning valve pressure will exceed working pressures and cause damage.
thanks guys.
Just got a call from the mechanic.
He mentioned the it could have been 2 of the following;
1) relief value could have been damaged/stuck by water corrosion or
2) piston damage could have been from a dislodged piece of steel from elsewhere that got caught against the piston and cylinder wall causing it to crack
other observations;
- judging by amount of water in the oil and the sludge on the top of lift cover seems like oil could be decades old. fresh oil to be replaced
- gaskets leaking near bolts that hold the foot
- PTO has a fair amount of play in and out, its not leaking so he mentioned just to keep an eye on it
His going to replace the whole cylinder and piston with a bigger later unit (with bigger bolts, replace all gaskets, relief valve, fill with fresh oil
fingers crossed I can then starting using this thing!
Update,
Getting the tractor back from the mechanic tonight and his sent me the bill. For anyone interested here is the breakdown of repairs
NOTE THIS IS IN AUSTRALIAN DOLLARS
   / MF35 cracked Hydraulic ram cylinder #6
I don’t know what the exchange rate is, but it looks like he did a good job and detailed exactly what he did. If you think his labor rate is fair, then I think he did a fine job.
I’m surprised the parts were that inexpensive.
   / MF35 cracked Hydraulic ram cylinder #7
In Us dollars that would be about $1112.56. More importantly though it's now fixed and the OP is happy. :thumbsup:
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
Kubota RTV500 (A47384)
2018 International DuraStar 4300 Dump Truck, VIN # 1HTMMMMNXJH633369 (A51572)
2018 International...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53472)
2022 New Holland...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53472)
GOODYEAR SET OF...
2025 High Country Cargo 8.5 x 20 Enclosed Trailer, VIN # 7FWBE2023S1035598 (A51572)
2025 High Country...
