MF35 4cyl Diesel - Died! Aagghh need help.
   / MF35 4cyl Diesel - Died! Aagghh need help. #1
SmallAcre
Victoria
MF35
I need some help diagnosing this - she's stuck in the middle of the back paddock at the moment with a hopper full of fertiliser :(
Was running fine, just spread fertiliser on 7 acres and was about to run over for a second pass when it hesitated for a second, then a couple of seconds later just cut out, as if I'd pulled the shut-off. It cranks over fine, I tried bleeding the fuel, I can get fuel coming out of the top bleed screw on the injector pump but get nothing from the injector lines? Could it be something with the injector pump?
Sorry - false alarm guys. I decided to look up how to actually bleed the system and found out I need to crank the engine to bleed the injector lines. Did this and it fired up fine - must have just got some air in the lines somehow? Got my spreading finished before dark - time for a beer.
   / MF35 4cyl Diesel - Died! Aagghh need help. #3
Wow, you must have been desperate, broke out the instructions. Glad you got it running, even if you did have to cheat.
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
Year: 2015 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 224,853 Plate: Body Type: (A50323)
Year: 2015 Make...
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
