I need some help diagnosing this - she's stuck in the middle of the back paddock at the moment with a hopper full of fertiliser
Was running fine, just spread fertiliser on 7 acres and was about to run over for a second pass when it hesitated for a second, then a couple of seconds later just cut out, as if I'd pulled the shut-off. It cranks over fine, I tried bleeding the fuel, I can get fuel coming out of the top bleed screw on the injector pump but get nothing from the injector lines? Could it be something with the injector pump?
