MF35 3 cyl perkins combustion caps blowby
   / MF35 3 cyl perkins combustion caps blowby #1
shrievy
TN
MF 35 Diesel
I have a MF 35 1960 3 cyl perkins I totally rebuilt, started up and engine sounds great. I am getting blowby on all three combustion chamber caps. The old cap gaskets were circular, and the ones I replaced are shaped like the cap (copper). I took them off and put on new cap gaskets (shaped like the cap) and this time sprayed the copper gasket spray like you use on the head gaskets. I made sure it was all clean on the caps and the head, (surface and inside the hole). Torqued it all up to specs again and started, after about 30 seconds I got blowby on one and within a minute all 3 caps were getting blowby. Can anyone help me with this one, frustrating? thanks, John
   / MF35 3 cyl perkins combustion caps blowby #2
G,Day shrievy.
If you still have the old copper gaskets and they look o.k. heat them red hot ,on the gas stove will do if you have nothing else red hot and let them cool of this will soften the copper ,put them on and paint wheel silver paint on the cap and both sides of the gasket put the cap on and tighten up before the paint dries I have done this before and it worked .
Happy Days .
Hutch
   / MF35 3 cyl perkins combustion caps blowby #3
I'm confused, what are combustion chamber caps?
   / MF35 3 cyl perkins combustion caps blowby #4
G.Day Rford .
I have worked on a lot of engines with Indirect fuel injection and I will try to keep this explanation as short as possible.
Basically the precombustion chamber aids ignition of the diesel fuel ,that is the atomised diesel is injected Partially to the main combustion area that is on top of the piston and the rest is injected into the precombustion chamber which is usually a spherical chamber with an access hole ,slot or transfer port leading to the main combustion area on top of the piston .
Being a compression ignition engine as a diesel is the air inside the precombustion area reaches higher temperatures very quickly due to the relatively small area of the chamber and consuequently when the atomised fuel is introduced , will encourage a positive reaction sending an explosive CHARGE via the precombustion chamber into the main combustion area resulting in a very efficient return on the ammount of fuel used.
Worth noting is the use of a PINTLE type fuel injector which provides a non directional and very precise volume of fuel, this also aids combustion in less than favourable conditions, especially in severely cold environments.
although more popular nowadays. I still feel comparing Direct injection with Indirect that the Indirect injection diesel is more fuel efficient and has a much more usable range of power when it comes to situations where the tractor is put to task, plowing as an example.
I hope this helps and goes towards answering your question.:)
Regards .
Hutch
P.S.
Answer to you question precombustion caps primarilly give access to the combustion area to allow maintenance and I would say machining during manufacture, the caps are sealed as in the case of the M.F 35 with copper washers or copper gaskets, Providing the caps are checked and are flat and the washers have been anealed they will GENERALLY seal although I have fitted all new parts and they still do not seal !!!!
   / MF35 3 cyl perkins combustion caps blowby #5
OK -- so the copper washers between the engine and the injectors aren't sealing.
   / MF35 3 cyl perkins combustion caps blowby #6
G.Day Rford .
read my reply to shrievy?????????????.
Hutch.
   / MF35 3 cyl perkins combustion caps blowby #7
Yes I did...it was too complicated for me....so I had to simplify it....
   / MF35 3 cyl perkins combustion caps blowby #8
G,Day Rford .
!!!!!! Simplify??.
Hutch.
   / MF35 3 cyl perkins combustion caps blowby #9
G,Day Rford .
!!!!!! Simplify??.
Hutch.
Yep...I'm not real sharp and when it comes to diesel engines not experienced either. Actually I was wrong in what I was thinking. Combustion caps are not the copper gaskets between the injector and the head. They are some triangular shaped cover that are next to the exhaust manifold on the indirect injection engines. They have an exhaust-type looking gasket, which is what was leaking. Here is a picture. They are the blue triangle pieces under the injectors and next to the exhaust manifold.
I've tried to attach a photo I stole off another site.
   / MF35 3 cyl perkins combustion caps blowby #10
G,Day R ford .
These are the wrong colour Massey caps are RED !!!.
Hutch.
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
WESSEX AT110 LOT IDENTIFIER 157 (A53084)
WESSEX AT110 LOT...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
