mf30 industial or turf
   / mf30 industial or turf #1
limpimpg
wi
cub,ford 9n
hello i'm working on a mf 30 ind/ turf with 200 loader.
attached a log splitter
tested worked for couple logs.figured good for next day
next day went to use splitter didn't work
3 pt lift arm goes up and down fine just no hyd fluid getting to attachment anything easy i should check before . removing lift plate.
took the ts300 selector isolator valve off. pretty much knew was not the problem but want to make sure.
3 pt most likley has not work in couple of years guessing.
mf 30 002.jpgmf 30 003.jpgmf 30 004.jpgmf 30 006.jpgmf 30 007.jpgmf 30 009.JPGmf 30 011.JPG
heres pictures for haven't taken the selector valve apart before very simple.
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
UNUSED WOLVERINE DB-15-84W 84" HYD ANGLE BLADE (A51248)
UNUSED WOLVERINE...
FOINEY ZOP EASY WELD (A51248)
FOINEY ZOP EASY...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
Rock wood travel trailer (A51694)
Rock wood travel...
