Tires MF245 Wheels Wobble At High Speed
   / MF245 Wheels Wobble At High Speed #1
taylorsrus
Faison, NC
Massey Ferguson 245
I recently purchased a 1979 MF245. The front wheels wobble when I run it at high speed on asphalt surfaces (highway). The front tires are fully inflated. If I deflated them some, would that solve the problem? If so, how much should I deflate them? I just don't want to under-deflate. Thank you!
   / MF245 Wheels Wobble At High Speed #2
Try and jack up the front end and see if the bearings are loose (common). They can be adjusted tighter without difficulty, just don't over tighten them. About hand tight is usually enough iirc.
If they are really worn they might need replacing but try adjusting them first. It depends how much road work you anticipate doing. For field work it's not a huge issue.
   / MF245 Wheels Wobble At High Speed #3
check your tie rod ends and king pins for wear along with slack in your steering sector
   / MF245 Wheels Wobble At High Speed #4
Had exactly that problem. The tie rod ends are worn out , replace Both ends as the problem will only be half fixed if you do one end and not both.
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
VERMEER 605F ROUND HAY BALER (A51243)
VERMEER 605F ROUND...
Kubota F3990 (A50322)
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
