MF245 lift problem
   / MF245 lift problem #1
halwest
Severna Park, MD
Ferguson TO35, Massey Ferguson 245
I have a Massey Ferguson 245 orchard model, Perkins 3 cyl. diesel, power steering, dual remote hydraulics. Purchased used. First thing I did was change all fluids and filters. Recently the rear lift will only raise when the tractor is running at a low (less than 500 RPM) If RPMs are increased the lift arms will lower. As the engine warms up I am able to increase the RPM's and the lift will work. Once everything is fully warmed up it appears to work normally. Through all this the auxiliary hydraulics
work normally. If I shut off the engine with an implement (5' finish mower) in a raised position the implement will stay in the raised position. Based on the casting # on the lift cover, the system is not pressure controlled. I have both the service manual and the operator's manual and can find nothing on this specific problem. Any help / thoughts on this would be greatly appreciated.
OOPS!. Tractor may or may not be pressure controlled. Not sure how to check. Meant to say tractor does not have a dash pot.
   / MF245 lift problem #3
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
91013 (A48082)
91013 (A48082)
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
