MF240 Steering Cylinder Question
   / MF240 Steering Cylinder Question #1
Cold Beer
Lillington, NC
Massey Ferguson 240
I'm replacing my power steering cylinders on a MF 240. The originals had part # 3401285M93. The replacements have part # 3774728M91. The difference is the new cylinders have a larger taper on the tie rod end (0.715") and the originals have smaller taper on tie rod ends (0.570"). The new ones also have larger ports for the hose connections. They are both the same length and diameter. The new ones are for models with hydrostatic steering and the original are just for hydraulic power steering (according to info on the net).
OK, my question: After having new hoses made to accommodate the larger ports and then having the steering arms machined to accommodate the larger tie rod tapers, will the new hydrostatic cylinders work with the older hydraulic power steering system? I have found 2 parts suppliers on the net that list these newer cylinders saying they work on both systems, but hopefully someone here can verify it.
Well, for prosperity's sake I'll answer my own post.
Yes, the newer steering cylinders will work. The steering arms had to be tapper-reamed out for the larger tie rod ends on the newer steering cylinders and custom hoses had to be made, which were probably still cheaper than MF hoses.
I also replaced the drag links and tie rods so the tractor steers much nicer now.
   / MF240 Steering Cylinder Question #3
Nice retro fit. :thumbsup: Obviously the stroke of both are the same too, if not you'd be taking a lot wider turns. :)
Complete Unloading Auger and Power Sweep (A50515)
Complete Unloading...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
Club Cadet 7000 54in Series Riding Mower (A50322)
Club Cadet 7000...
John Deere Z915B (A50121)
John Deere Z915B...
Schuler 220 BF Feed Wagon (A50514)
Schuler 220 BF...
