MF240 Steering Cylinder Question
   / MF240 Steering Cylinder Question #1
Cold Beer
Lillington, NC
Massey Ferguson 240
I'm replacing my power steering cylinders on a MF 240. The originals had part # 3401285M93. The replacements have part # 3774728M91. The difference is the new cylinders have a larger taper on the tie rod end (0.715") and the originals have smaller taper on tie rod ends (0.570"). The new ones also have larger ports for the hose connections. They are both the same length and diameter. The new ones are for models with hydrostatic steering and the original are just for hydraulic power steering (according to info on the net).
OK, my question: After having new hoses made to accommodate the larger ports and then having the steering arms machined to accommodate the larger tie rod tapers, will the new hydrostatic cylinders work with the older hydraulic power steering system? I have found 2 parts suppliers on the net that list these newer cylinders saying they work on both systems, but hopefully someone here can verify it.
Well, for prosperity's sake I'll answer my own post.
Yes, the newer steering cylinders will work. The steering arms had to be tapper-reamed out for the larger tie rod ends on the newer steering cylinders and custom hoses had to be made, which were probably still cheaper than MF hoses.
I also replaced the drag links and tie rods so the tractor steers much nicer now.
   / MF240 Steering Cylinder Question #3
Nice retro fit. :thumbsup: Obviously the stroke of both are the same too, if not you'd be taking a lot wider turns. :)
2012 Volvo XC70 Wagon Sedan (A50324)
2012 Volvo XC70...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
