2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 7,357
I looked at a 1995 or 1996 MF231 with about 1200 hours. Seller wants $7500. Barn kept. Only question I have is some fluid leakage on both sides of tractor roughly in the area of the lift control on other side and whatever the other control is on the other. I didn't see an obvious leak, but the transmission housing was damp from some kind of fluid. Any ideas on this one?
Then I looked at a 2001 231S with 1700 hours for $6750. Has been kept outside. Both power steering cylinders were dripping. The steering column had what appeared to be hydraulic fluid leaking from it some way or the other. So I assume both cylinders and something on the steering column will have to be worked on. The clutch also felt like it was working, but had a narrow range of engagement suggesting that a new clutch is not that far off.
Essentially, I need a bigger tractor to mow with. Ideally, I'd like to have a FEL which neither one of these has. I'm also not sure if these models will accept a FEL without adding another hydraulic pump? Does anybody know?
