MF205 Starter
   / MF205 Starter #1
WhirldWorks
Rockdale, Texas
Massey Ferguson MF205
Here we go again...no sooner did I get the head gasket replaced and now the dang thing won't start. I turn the key and sometimes I get nothing and sometimes I get a few clicks (with a fresh battery).
I'm thinking I might have burnt the starter up when it had the cylinder head problem, but I dunno. Is this a starter problem or the solenoid?
   / MF205 Starter
Wow, almost 400 views and no replies. Oh well...bought a new starter, new battery and new cables...and guess what...NOTHING CHANGED. I'm fed up with this "bargain deal" tractor,
   / MF205 Starter #3
What happens if you jump it with a wire?
   / MF205 Starter #5
Check the ground cabel one more time.
   / MF205 Starter
I guess it would help if I actually installed all the new stuff I bought. I installed everything but the new ground wire. I guess I was so frustrated I overlooked that. Anyway, I took the old one off, made sure the ground connection was clean and installed the new one. It starts now :)
I must say though, this new starter is worlds better than the old one before it died. Sometimes I'd have to try 2 or 3 times at 5 seconds each turn of the key to get this thing started. Now I barely turn the key and she's running!
   / MF205 Starter #8
Great to hear :)
   / MF205 Starter #9
where did you buy your starter and did you get any info on the manufacturer, I need a stater for a hinomoto e14
   / MF205 Starter
I ordered mine through Sears for about $280, but the manufacturer was actually RareElectrical.com. Here is the link, but I am not familiar with thehinomoto. I will say that the mounting plate didn't fit exactly right and I had to grind it down to get it to fit around a part of the engine block that stuck out. Once I did that it slid in perfect and works like a charm. Sears.com
DOOSAN DL300-3 HYD 4N1 COMBO BUCKET (A51247)
DOOSAN DL300-3 HYD...
2022 JLG R3246 ELECTRIC SCISSOR LIFT (A51247)
2022 JLG R3246...
2023 Bobcat E32i Excavator (A51573)
2023 Bobcat E32i...
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
