MF205 Starter
   / MF205 Starter #1
WhirldWorks
Rockdale, Texas
Massey Ferguson MF205
Here we go again...no sooner did I get the head gasket replaced and now the dang thing won't start. I turn the key and sometimes I get nothing and sometimes I get a few clicks (with a fresh battery).
I'm thinking I might have burnt the starter up when it had the cylinder head problem, but I dunno. Is this a starter problem or the solenoid?
   / MF205 Starter
Wow, almost 400 views and no replies. Oh well...bought a new starter, new battery and new cables...and guess what...NOTHING CHANGED. I'm fed up with this "bargain deal" tractor,
   / MF205 Starter #3
What happens if you jump it with a wire?
   / MF205 Starter #5
Check the ground cabel one more time.
   / MF205 Starter
I guess it would help if I actually installed all the new stuff I bought. I installed everything but the new ground wire. I guess I was so frustrated I overlooked that. Anyway, I took the old one off, made sure the ground connection was clean and installed the new one. It starts now :)
I must say though, this new starter is worlds better than the old one before it died. Sometimes I'd have to try 2 or 3 times at 5 seconds each turn of the key to get this thing started. Now I barely turn the key and she's running!
   / MF205 Starter #8
Great to hear :)
   / MF205 Starter #9
where did you buy your starter and did you get any info on the manufacturer, I need a stater for a hinomoto e14
   / MF205 Starter
I ordered mine through Sears for about $280, but the manufacturer was actually RareElectrical.com. Here is the link, but I am not familiar with thehinomoto. I will say that the mounting plate didn't fit exactly right and I had to grind it down to get it to fit around a part of the engine block that stuck out. Once I did that it slid in perfect and works like a charm. Sears.com
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
New Wolverine Skid Steer Root Rake Bucket Attachment 34'' (A53002)
New Wolverine Skid...
SCHAFFER 2430SLT LOT NUMBER 150 (A53084)
SCHAFFER 2430SLT...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
