MF165 Using Hydraulic Remotes and Lift
   / MF165 Using Hydraulic Remotes and Lift #1
AllWaysBreakinSomething
Cherryville, NC
MF165, Ford Workmaster 661, Super A, Bobcat 943
I'm going to start this question by saying that I have a cheap single lever remote on my MF165 and want to change it. Now I've seen a cross hydraulic valve on my Dad's MF165 but is has an adapter mounted to the tranny between the standard 3 level valve. Anyone know the part number or where to get one of these? This is the only configuration I've seen that you can use the 3pt lift and multiple hydraulic remotes. If you need a picture I can oblige. My Dad's tractor has three levers. On on the left is double acting and will stay forward as to supply continuous flow to the lift. Put in the center it will not let the fluid drain when using one of the other two levers which control the two remotes. I've called Cross and they don't have any information on the tractor. They just want to sell the standard remote hydraulic valve. If I can get the transition adapter this is a no brainer. Help Big Dean or SoundGuy or anyone else they has the info. :( It will be greatly appreciated.
   / MF165 Using Hydraulic Remotes and Lift #2
G'day not sure of the valve you are talking about can you post a pic and we may be able to set you on the right path
Jon
Cross is a brand name and they make really good ones. I need an adapter that makes the transition from the standard mount under the MF165 seat to the standard remote valves on the market. I can take a picture if this helps and posted later today.
   / MF165 Using Hydraulic Remotes and Lift #4
I am thinking that particular setup may a MF dealer item only. Anyone know of aftermarket kits for these? I could use a couple myself? Ken Sweet
   / MF165 Using Hydraulic Remotes and Lift #5
G'day Ken have a look at the bare co site they have a good range of hyd parts for the masseys, you may want to look into becoming a dealer for them we are over here and can recommend their gear and service ( their pricing is not bad either :thumbsup:)
Jon
   / MF165 Using Hydraulic Remotes and Lift #6
Jon
I checked them out and they have a nice line of parts. I did not see complete hydraulic kits, only valves. Most of our customers want the whole kits. I will have my Son check into a dealership. We already have A&I and Tisco, so the parts may overlap too much. Thanks, Ken Sweet
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50323)
2020 Exiss Escape...
2015 Caterpillar D6K Crawler Tractor Dozer (A50322)
2015 Caterpillar...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
Caterpillar 345D Hydraulic Excavator (A50322)
Caterpillar 345D...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
