MF165 massive hydraulic fluid "weep hole" leak
   / MF165 massive hydraulic fluid "weep hole" leak #21
SIMassey on your 135 it sounds like you may have a completely worn out "nose cone". This allows the oil to bypass internally. It mimics perfectly a worn out multipower clutch pack. I had the nose cone remanufactured and got back a text book perfect, gear shift.
Dont want to hijack this thread so will try to keep it brief.
Do you mean the housing the multipower valve is mounted to?? This has the pto splined drive shaft mounted in it.
When it shifted it was a full throttle shift and definitely jerked me backwards. Based on that, I always suspected internal leakage instead of either pump pressure or bad multipower clutch.
Did they bore out housing and sleeve it?
   / MF165 massive hydraulic fluid "weep hole" leak #22
Hello SIMassey, I don't know . Took tractor to dealer to fix multipower. Told them symptoms and they tested and agreed, worn multipower. They tore things down and found actual problem was quote "a totally worn out nosecone" They told me it was remanufactured. I have no other details
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
KSI Conveyor (A55301)
2012 PETERBILT 587 SLEEPER (A54313)
2012 PETERBILT 587...
2015 DODGE RAM...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
