MF1635 - front wheel assist will not engage , 20 inch snow , worthless
   / MF1635 - front wheel assist will not engage , 20 inch snow , worthless #1
bm3
warsaw va
MF 1635 , JD 3203 , JD 1070
:mad:
First time it has happened and when needed the most . Any suggestions ?? tractor stopped , clutch in , nothing ! and without it the **** thing will not move in the snow
   / MF1635 - front wheel assist will not engage , 20 inch snow , worthless #2
If it has been working ok before this, I bet the lube/grease may be cold and stiff. Also if any moisture happens to be in that area, it may be froze. Try to get some heat in that area and I bet it will be fine. Ken Sweet
Thanks Sweettractors ! will try it now , first time it has ever failed to engage
No go still will not engage. Tractor is a big let down
   / MF1635 - front wheel assist will not engage , 20 inch snow , worthless #5
Is the 4wd lever moving freely? Does it seem to be going through its full range of motion?
Yes moves freely, seems to go through full motion. Loading and unloading it on trailer is when its used the most , have babied the tractor , use a JD 3203 most of the time so the 1635 only has 54 hours. I left the JD at another place I have and keep the 1635 at home , big disappointment
   / MF1635 - front wheel assist will not engage , 20 inch snow , worthless #7
You might(if you haven't already) check the drive shaft couplers. Not a likely problem with such low hours but who knows? They are probably only held in place with lightweight snap rings which have been known to fail, or work out of their grooves allowing couplers to slip out of engagement.
   / MF1635 - front wheel assist will not engage , 20 inch snow , worthless #8
The last time I had a problem like that, A group of new tractors would do the same thing even in pretty mild temps. The manufacturer had used a way too high viscosity lube. We had to change lube to a lower viscosity that would allow the gears to slide easier on the shafts. Ken Sweet
   / MF1635 - front wheel assist will not engage , 20 inch snow , worthless #9
Agreed. We have to keep it clean and lubed on the side of the transmission. 800+ hours and no issues.
   / MF1635 - front wheel assist will not engage , 20 inch snow , worthless #10
Have you got a way to heat the whole unit up with a heater and a tarp. Might free it up. In the winter with snow on the ground, I usually leave mine engaged all the time.
Good luck
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
KUBOTA ZD1211 (A53084)
2008 Ford F-250 (A53472)
2008 Ford F-250...
