mf1428v freewheeling downhill
   / mf1428v freewheeling downhill #1
GaryS
franklin park, pa
Kubota L3901 & LA525
Just started my first grass cut of the year and had a terrifying experience. I have steep hills and use a Woods rear finish mower. I started down a steep hill only to find the tractor freewheeling. I was able to slow it but it scared the daylights out of me.
I tried it again on a less steep hill and it started gaining speed again even after I took my foot off the pedal. Using the brake stopped it but it's never done that before.
Has this happend to anyone before? Is this something I can fix? I use the brush hog on even steeper hills and I'm concerned this is going to mean a big repair.
gary
   / mf1428v freewheeling downhill #2
drop it into lowest gear, and let the engine compression itself keep the tractor slowed down. at least that is what i do.
if i am in a high gear, it can get rather frighting, or when i push the clutch in.
i always and i do mean always change to lower gear well before i hit a steep hill. were i can push the clutch in, and stop completely with ease. before going down a steep hill.
trying to change gears going down a hill = bigger chance of not being able to pop the gear back in. and at same time gaining a lot of extra speed.
ya, it may seem like a turtle going down a hill in lowest gear possible. but once you hit a hole or something happens, having that slow speed keeps that heart from jumping a few beats.
if you mow backwards up the hill. can be safer. this way the engine and lower gear is trying to climb the hill.
I've used the tractor here many time before and didn't have this issue.
Yesterday I drained & replaced the hydro oil and the oil in the front axel. I then tested it again.
It acts like it's in two wheel drive going down a hill. The back tires stop spinning but the fronts continue to roll.
On a Hydro, is there a difference between pulling power and stopping power? The front tires seem to be able to pull the tractor but not to stop.
It's raining now and I need to be 100% certain that it's really really in 4wd but I''m 99.99% sure it is.
I don't think this is a MF issue. I'm going to post this question again in the general repair form.
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
