MF135 temperature sender unit
   / MF135 temperature sender unit #1
justinS
My 135's temp gauge has been disconected and I'm struggling to find the sender unit on the block. Can anyone give me rough directions as to where I might find it?
   / MF135 temperature sender unit #2
Should be on the left side of the thermostat housing on the front of the head
That's brilliant - thanks JJ.
   / MF135 temperature sender unit #4
I changed my temp sending unit along with my fuel sending unit today. Temp unit still doesn't work. If I short the middle terminal and the driver side terminal behind the gauge, the gauge goes full temp. If I short the wire at the sending unit to ground (as the shop manual says) I get nothing.
Anyone have similar issues? Is there a temp specific fuse? My shop manual says little else. Only reason I know where to find the sending unit is from this thread.
   / MF135 temperature sender unit #5
My temp guage sending unit was cut off when I bought it, about 3 inches from the send unit where it screws into the head. Didnt have time to wait on finding a factory replacement, so I installed an "off the shelf" temp guage and sending unit. It seems to function ok, dont know how long it will hold up in the long run. The only wires on it are for the light.
   / MF135 temperature sender unit #6
G'day run a new wire on the outside of the loom and test it sounds to me like a broken wire
Jon
   / MF135 temperature sender unit #7
The wire from the sending unit to the gauge is good. I tested it with an ohm meter.
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
STORAGE FEES (A52576)
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 42-6FGCU25...
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
