MF135 power steering
   / MF135 power steering #1
Kenfyoozed
Mobile, Al
1974 MF135
I am trying to check if my power steering is working. I am assuming it isn't. It's a 1974 135. I read in my manuals that there should be a power steering fluid resevore. I can not find anything of this nature on my tractor. I have the "cesna" pump on the front left if you are looking at the tractor. Front right if your sitting on it. There are 2 lines that run from it, to the steering column. Im sure grandpa took it off if it stopped working. So what parts am I missing. If I would get the parts manual as suggestd I wouldnt have to ask these questions.:rolleyes:
   / MF135 power steering #2
I think that pump and resevoir are one -- should be a plug on top to fill -- not positive -mine is a gasser, yours must be diesel or 3 cyl gas. As I remember it if the Cessna pump is leaking you can try and fix it but most say replace it. Parts manual has an exploded view. If tyou decide to take it apart, scribe the housing and plate. Otherwise you might do a little bit of swearing when you go to put it back together:mad:
Thanks, after restuding the diagram, I now see that. Thanks.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2017 Claas Jaguar 860 Forage Harvester (A52748)
2017 Claas Jaguar...
2006 International 4400 DT466 (A50120)
2006 International...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50323)
2015 Big Tex 70PI...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
