mf135 injector pump
/ mf135 injector pump #1
kayak
newport,TN.
67' MF 135
i have a 66' 135 which is leaking fuel from the top cover of the pump,i'm looking for an exploded view of the injector pump so i can replace the gasket from which it is leaking.i havent worked on any diesel equipment before,so i'm not familiar with any components.i just need to know how to remove the top cover without causing any further damage.
/ mf135 injector pump #2
The following exploded view parts diagram for a CAV DPA diesel injection pump may or may not be for you exact model, but it should give you the information you need.
thanks for the diagram,it looks fairly close to it. i just needed to know what was under the top cover.thanks again massywv.
/ mf135 injector pump #4
If you save the diagram to your computer and view it there, it will be much larger than it's displayed in my post above. Alternatively, you may also wish to view the full size diagram in your browser. Here is a direct link to the diagram image.
http://i46.tinypic.com/keubg7.jpg
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
Gradall no crank no start (A61568)
Gradall no crank...
