MF135 Hydraulic Filter
   / MF135 Hydraulic Filter #1
JD2007
North Carolina
John Deere LT133 & JX75
My dad has got a MF135 from the early 70s with the Perkins Diesel. I ordered a tech manual this past week but it won't be here for several weeks & I was needing to know if this tractor has a hydraulic filter & if it does then how do you gain access to it? Thanks.
   / MF135 Hydraulic Filter #2
Yes it has an internal screen. You can get to it threw the side plate near the rear tire.
Is it a reusable screen or does it need to be replaced? Is it behind the plate next to the right rear tire where the dipstick is? Thanks.
   / MF135 Hydraulic Filter #4
Here's the info from the MF135 operator manual
Good luck
   / MF135 Hydraulic Filter #5
I don't know about your 135, but my 165, the filter is between your feet on the left side of the case (if your sitting in the seat).
I'll see what I can get figured out, thanks for the responses!
   / MF135 Hydraulic Filter #7
Picture of it from the top looking down. As has been said, it's adjacent to the side cover.
   / MF135 Hydraulic Filter #8
I would replace it. This is a screen filter and is pretty cheap. This is a filter that gets changed about ever 10 to 15 yrs or when people find out about them. :thumbsup:
Well dang. I was under the assumption that it didn't have a hydraulic filter(should have asked on here first), so I changed the hydraulic fluid this past weekend...is it possible to replace this filter without having the drain the fluid?
   / MF135 Hydraulic Filter #10
If tractor has 2 stage foot clutch for PTO strainer can be removed through PTO shift cover access hole. Tractors with hydraulic PTO three point lift cover has to come off as oil lines are attached to side cover on inside, can't be removed until lift cover is off first.
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
BAUMA LIGHT TX 12 LOT NUMBER 224 (A53084)
BAUMA LIGHT TX 12...
