MF1240 HARD STARTING
/ MF1240 HARD STARTING #1
DONALDK
SW Ontario
JOHN DEERE
i have been having a hard starting issue with my MF1240.
The tractor requires using the glow plugs to start even when warm.
When cold. the tractor requires 3 or more attempts to start and each time requiring the glow plugs.
The cold start produces white smoke and then the engine stops almost like it is fuel starved (fuel filter good).
Someone had suggested new glow plugs as a solution to hard starts? Any thoughts?
Is replacing glow plugs on a 3 cyclinder tractor costly?
Thanks in advance.
/ MF1240 HARD STARTING #2
If you tractor will not start without glow plugs when it's warm, then glow plugs are not the problem. Most likely it's either compression or fuel delivery related.
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
JOHN DEERE 4230 TRACTOR (A64277)
JOHN DEERE 4230...
2022 EZ-GO ELITE...
2018 Ford F-150 4X4 (A62679)
2018 Ford F-150...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
