MF1033/HINOMOTO E2304
/ MF1033/HINOMOTO E2304 #1
mf1033
LOOKING FOR SHIFT LEVER ASSEMBLY. HALF SPHERE, MAYBE CALLED WOBBLER IS WORN AND PIN THAT HOLDS SHIFTER IN PLACE POPS OUT OF ALIGNMENT CAUSING PROBLEMS WHEN TRYING TO SHIFT GEARS. MAY TRY LONGER PIN OR SOMETHING ELSE IF I CANT FIND ANY PARTS. PIN SLIDES UP AND DOWN IN ELONGATED HOLES AND GEAR SHIFT RISES TOO HIGH TO ENGAGE TRANSMISSION. ANY SUGGESTIONS OF WHERE TO FIND PARTS OR FIX THIS PROBLEM IS APPRECIATED. ALSO MY MECHANIC SAYS TRANSMISSION IS IN EXCELLENT SHAPE WITH NO WEAR THAT MIGHT CAUSE THIS PROBLEM. THE LEVER JUST WONT STAY LINED UP.
/ MF1033/HINOMOTO E2304 #2
West Kentuky tractor parts or Farmland tractor supply might be able to fix you up.
Thanks, will try that.
TPL MECHANICS BODY LUBE SKID (A60430)
TPL MECHANICS BODY...
2021 NORAM 65E TURBO MOTORGRADER (A60429)
2021 NORAM 65E...
LOT LOCATIONS (A59904)
2014 Ford Escape (A59231)
2014 Ford Escape...
2019 Ford Transit Connect XL Cargo Van (A59230)
2019 Ford Transit...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
