MF1033/HINOMOTO E2304
   / MF1033/HINOMOTO E2304 #1
mf1033
LOOKING FOR SHIFT LEVER ASSEMBLY. HALF SPHERE, MAYBE CALLED WOBBLER IS WORN AND PIN THAT HOLDS SHIFTER IN PLACE POPS OUT OF ALIGNMENT CAUSING PROBLEMS WHEN TRYING TO SHIFT GEARS. MAY TRY LONGER PIN OR SOMETHING ELSE IF I CANT FIND ANY PARTS. PIN SLIDES UP AND DOWN IN ELONGATED HOLES AND GEAR SHIFT RISES TOO HIGH TO ENGAGE TRANSMISSION. ANY SUGGESTIONS OF WHERE TO FIND PARTS OR FIX THIS PROBLEM IS APPRECIATED. ALSO MY MECHANIC SAYS TRANSMISSION IS IN EXCELLENT SHAPE WITH NO WEAR THAT MIGHT CAUSE THIS PROBLEM. THE LEVER JUST WONT STAY LINED UP.
   / MF1033/HINOMOTO E2304 #2
West Kentuky tractor parts or Farmland tractor supply might be able to fix you up.
Thanks, will try that.
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
Modine Shop Heater (A51573)
Modine Shop Heater...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
Engel 20' Boat (A50121)
Engel 20' Boat...
