Traction MF1030 No 4 wheel drive
   / MF1030 No 4 wheel drive #1
tonyta
Spencer,WV
MF 1030
When lever is in 4 wheel drive I have none,it acts like something unhooked? how would you get inside to see?
   / MF1030 No 4 wheel drive #2
I would check and see that the set screw where the 4wd lever meets the shaft is tight. It would be the most likely cause.
Thanks,I was looking at diagram and seen a pin where the inside lever and outside lever connect and thought that pin could be the problem going to check it later thanks for your help Tony
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
Unused Delta Crash...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
Wacker Neuson G25 20kW Towable Diesel Generator (A51691)
Wacker Neuson G25...
PAIR OF 42" W X 5' L MEGA RAMPS (A51247)
PAIR OF 42" W X 5'...
