Traction MF1030 No 4 wheel drive
/ MF1030 No 4 wheel drive #1
tonyta
Spencer,WV
MF 1030
When lever is in 4 wheel drive I have none,it acts like something unhooked? how would you get inside to see?
/ MF1030 No 4 wheel drive #2
I would check and see that the set screw where the 4wd lever meets the shaft is tight. It would be the most likely cause.
Thanks,I was looking at diagram and seen a pin where the inside lever and outside lever connect and thought that pin could be the problem going to check it later thanks for your help Tony
