MF1020 Transmission Fluid Plug Size? Please Help!
   / MF1020 Transmission Fluid Plug Size? Please Help! #1
paatchen
NC
MF1020
Thanks so much for any help you may have. I recently purchased a 1020 and the guy rigged up a plug for the transmission fluid reservoir and it needs a legitimate replacement.
What is the size of the bolt/plug that is used for that reservoir?
Thanks much!
   / MF1020 Transmission Fluid Plug Size? Please Help! #2
You probably need to get that from a dealer. If it's like my 1010, it's a magnetic plug.
Thank you much. I will call them today and see what the deal is.
   / MF1020 Transmission Fluid Plug Size? Please Help! #4
I just saw thougth I'd mention this.You say that what was in there for a plug was what they use in a boat[was that the expandable plug] What you better do before ordering a plug take a look into the hole where the plug goes and make sure that the threads haven't been stripped out.Could be why they used a plug like that instead of the proper one.If the threads are stripped out then your going to have to either buy a bigger size self tapping plug and thread it into the hole.{these plugs are avaliable at say Napa.} just make sure you put it in straight so it seals properly.Of course you can buy a kit thats a helicoil meaning you use the tap that comes with the kit and then screw in a helicoil making new threads for a new plug.Or you can use a biggier size tap to make new threads and put in a larger size plug.Its not hard at all to do.The first idea I mentioned is the easiest,this was a common fix for many a oil pan at one time.Larry
Thanks so much Larry! I will look into it. I contacted a Massey dealer here in charlotte (Godley Auction), he said I can order a new plug for $22 but advised what you mention of making sure it isnt stripped. I will take another look at it tomorrow morning.
Thanks again!
Toph
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
1999 Case 90XT Skidloader (RUNS) (A50774)
1999 Case 90XT...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
