MF1020 Ignition switch
   / MF1020 Ignition switch #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
I need a replacement Ignition switch for my MF 1020 made by hino. 21 HP Diesel it has 5 leads with screws. Same tractor as the DA 5220. MF # 3280565M92 or Agco # 72102514.
Mine is corroded inside. Anything I can soak it in? It's has a little drain hole on it but a rolled edge so i can't take it apart.
   / MF1020 Ignition switch #2
That part number is the same as the number for an ignition switch on a 1010, which is the model I have. The part cost me $75 a few years ago when I replaced mine.
I do not know of any way to clean up the one you have. A dealer should be able to get it for you though. You might want to check eBay too.
I think these switches can't be all that different from those used on other tractors, and if you check on the Chinese Tractor Owners Association forum, you should be able to find a thread on this topic. I think the Jinma owners typically swap the chinese switch for a Ford switch if I'm not mistaken. And it might be a lot cheaper assuming it fits your dash opening. I've learned a ton about these tractors from reading about the problems and solutions the Jinma owners have come up with.
Good luck.
   / MF1020 Ignition switch #3
I have a bad one now, tractor wont run, If you have any sugestions on wer to find one?? I have ben looking>
Paul
   / MF1020 Ignition switch #4
Try Godley auction in Charlotte NC. Don't have a phone number, but they have a web site. I think I've read somewhere before that they handle used parts.
Welcome Page
You may find some parts here:
TractorHouse.com - Featured Parts Dealers
OR here:
West Kentucky Tractor Parts - Kevil, Kentucky
I've not tried any of them, just captured them from various threads along the way. But I'd still go with a dealer if it were me. Get a new switch while you still can and it might last a long time for not much more coin than a used one.
look up Yanmar Ignition switch on ebay. Mine looks identical to those with 5 tabs and screws.
   / MF1020 Ignition switch #6
Squirt some WD-40 into the key slot.
That will do 2 things, soften up the dry lubricant and flush out any crud.
Worked for me just fine.
Age just plain dries the lube and it becomes hardened to the point that the contacts no longer get made.
ps, I have dismantled a few old switches just to prove my theory.
   / MF1020 Ignition switch #7
G'day you should be able to use on aftermarket copy of a lucas on if you have the room they are avail pretty cheap
Jon
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2020 COLOMBO TM LOT NUMBER 217 (A53084)
2020 COLOMBO TM...
2014 Chevrolet Tahoe (A52377)
2014 Chevrolet...
2003 KENWORTH T2000 (A52472)
2003 KENWORTH...
