Oil & Fuel mf1020 hydrolic fluid plus size?
   / mf1020 hydrolic fluid plus size? #1
paatchen
NC
MF1020
mf1020 hydrolic fluid plug size?
I bought a Mf1020 which has a stripped hydrolic fluid reservoir bolt. I would like to buy an oversized bolt but I can not find what size the original plug is. Thanks for any help.
   / mf1020 hydrolic fluid plus size? #2
Take some calipers,and measure the hole,if you don't have calipers then take a ruler or tape measure and measure the hole.If you have some bolts at your disposal stick some in the hole to see what size the hole is.I'll bet it's got to be upwards of a 1/2" hole more then likely a metric but no matter if your going with a self tapping pan plug as it will make it's own threads. could be 9/16" ,5/8" ,11/16",3/4" measure the old hole then you'll know what size to buy.I'am sure I've mentioned other ways such as helicoil,larger size tap for larger plug.Different ways to fix just your preference.Larry
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2013 Infiniti M37 Sedan (A50324)
2013 Infiniti M37...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2006 John Deere HPX Gator 4x4 Utility Cart (A50322)
2006 John Deere...
