MF1010 which oils to use ??
   / MF1010 which oils to use ?? #1
JJ. in B.C.
BC. Canada
Hi Guys, my first post on this forum. Internet friend of mine in Malta just purchased a 1986 MF1010 and needs to know the correct oils to use in engine and transmission. He would also like to get an owners manual, do AGCO dealers still have them ? Any help you can give will be much appreciated.
Regards, JJ.
   / MF1010 which oils to use ?? #2
bloody peasant,
Thanks for the info, JJ.
   / MF1010 which oils to use ?? #4
JJ. in B.C. said:
bloody peasant,
JJ, sorry I forgot to look at the manual last night :( got busy putting my new drill press together and lost track of my intentions. I'll try again tonight :)
   / MF1010 which oils to use ?? #5
Ok, finally got to the manual :( sorry again
For above 40 deg. F it recommends either SAE 30W or SAE 10W-30
For below 40 it only recommends the SAE 10W-30
The fuel injection pump uses the same oil, although it should only be changed every 300 hours or so.
For the tranny/hyd (and front axle if FWD) it recommends the MF Permatran, but says you can use any SAE 80W to SAE 90W oil. Note it uses the same oil (and even the same reservoir) for both the tranny and hydraulics. However if you have FWD there is a separate front axle reservoir.
   / MF1010 which oils to use ?? #6
Im not sure on the MF-1010 but on my MF-1040 the front has three seperate resevoirs. The reduction units on the left and right and the center resevoir.
   / MF1010 which oils to use ?? #7
Yep that's probably right, I've got the 2WD so I wouldn't know for sure :(, seems like I do remember seeing something about multiple drain plugs when I skimmed that section of the manual though
Thanks very much for all the information guys, i will pass it along.
Regards, JJ.
   / MF1010 which oils to use ?? #9
.... However if you have FWD there is a separate front axle reservoir.
A separate reservoir as in the engine compartment or just the housing?
I see two plugs on top of the axles, one on each side.
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
