MF1010 bucket hydraulics are backwards
   / MF1010 bucket hydraulics are backwards #11
Are you currently happy with the rollback and dump angle?
If so, measure retracted length from pin Center to pin Center. And the stroke length.
Shorter gets more roll back but less dump.
Longer gets less rollback but more dump as long as you don't bind the rod on the loader arm.
If the bucket has hard stops, take cylinder off and physically curl bucket all the way back til it hits the stops, same for dump.
Measurements are pin Center to pin center
OK thanks. No, I am not happy, there is no "rollback", at all. Dump angle is good. The lower fitting, the double one, seems extremely long. I wonder if one of the welded cylinders like this one IMW-212 - 2" Bore, 12" Stroke Welded Hydraulic Cylinder would change the length issue? It seems like the fittings are shorter, thus longer cylinder? I have no idea on this.
On the rollback, there are hard stops, not sure on the dump. I will look tomorrow, and see if I can get some measurements.
If there are hard stops for the dump, does that mean that I split the difference between the two? Or is it, at dump stops, that is extended length, and roll back stops are closed length?
Here's a picture I found, but the hydraulics on this one are totally opposite of mine.
I assume this one is correct though. Those look like welded cylinders to me. Also look pretty long too.
   / MF1010 bucket hydraulics are backwards #15
Rollback stops should give retracted length...or close. Dump stops give extended length. And if anything, go longer. You don't want the cylinder too short to contact the hard dump stops IMO
The cylinders in the pic above do look pretty long. Would contacting the dump stops be worse than contacting the roll back stops? I definitely want more roll back, currently there is none.
So if there are no dump stops, then do I guess?
Sorry, this is all new to me.
   / MF1010 bucket hydraulics are backwards #17
Contacting rollback stops is optional.
Hitting dump stops....yes you want to do that.
If not, every time you dump "hard" you are putting a ton of stress on the cylinder cap. Not to mention if you have the bucket dumped all the way and put the cutting edge into the ground to push something (which is a "no no", but I think everyone has done it at some point in time). You want a physical stop to take the stress off the cylinder.
OK I get it. I took a look at it today, and it has stops both ways. The dump stops are a welded bar that crosses the bracket. I do not have time currently to disconnect the bucket and measure, but that makes a HUGE difference for me when it comes time to order new cylinders. At least now I know what to look for and what to measure.
Since these are NOT anywhere close to originals, any guesses on what capabilities I should expect for the new cylinders? Such as rod diameter, and bore size?
   / MF1010 bucket hydraulics are backwards #19
The 1010 and 1014 loader are pretty small.
Whats the current cylinder size? Bore and stroke? I cant see needing a real big cylinder. Maybe 1.5" max diameter. My L3400 (which was a good bit bigger tractor) had 1.77" cylinders.
Baileynet that I linked earlier has a LOT of 1.5" cylinders with 1" rods. Stroke lengths from 12" to 24" in 2" increments. I'd see which one of those would be closest to working.
@ 2500PSI each cylinder can retract with 2500# or so of force. So thats quite a bit of rollback force even accounting for the geometry of the loader.
LD1
Thanks, that helps. I will check the current ones and see what they are. Am I correct in assuming, that smaller ones move faster, but have less power? That would make sense to me.
OK I went out and did some looking. The existing INCORRECT ones are Spencer #20X12-L 20TC12-112, all 4 of them. Assuming CT12 means 12" stroke, and that's what it measures, extended, but that leaves about 1-2" short of the dump stops. The name tag does list working PSI at 2500. Based on this I assume the 2 for the main arm are too short also, possibly.
The rod is either 1" or 1 1/16", I didn't put caliper on it, but can when ordering date gets closer.
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
1981 Case 245 2wd tractor with Rotary cutter (A51039)
1981 Case 245 2wd...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
Chevrolet Silverado Pickup Truck Bed (A49461)
Chevrolet...
Toro Workman Cart (A50322)
Toro Workman Cart...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
