MF GC2310 steering motor bushings
   / MF GC2310 steering motor bushings #1
Mattmotors
Massey Ferguson 2310 TLB
Quick question. How do I pull the steering wheel off? I have a fly wheel puller for outboard motors that matches up, How ever, the 3 holes in the steering wheel is just plastic. What kind of screws am I using to screw into the steering wheel to pull it off the shaft? As far as the bushing, I know that they are no longer available. I have some rubber washers that were for a trolling motor mount that match up pretty good. Thanks in advance , Matt.
   / MF GC2310 steering motor bushings #2
Quick question. How do I pull the steering wheel off? I have a fly wheel puller for outboard motors that matches up, How ever, the 3 holes in the steering wheel is just plastic. What kind of screws am I using to screw into the steering wheel to pull it off the shaft? As far as the bushing, I know that they are no longer available. I have some rubber washers that were for a trolling motor mount that match up pretty good. Thanks in advance , Matt.View attachment 724033
Not sure how your wheel is constructed but my wheel is also mostly plastic. The metal part has to be hit with a punch or chisel from below. Can be quite difficult to remove.
Hopefully someone else here has a better method!!
   / MF GC2310 steering motor bushings #3
The book says:
1) Use a flat screwdriver to remove the middle cap on the steering wheel.
2) Remove the nut
3) Pull the steering wheel upwards off the splined steering shaft.
I would assume by reading this that is should be able to pull it off without needing any tools to do it.
  • steering1.pdf
I got it off. I read deeper into tractor by net. 3 inch 1/4 20 screws in the holes. nuts underneath the steering wheel, snug it up, applied some torque and off it came. I did keep the nut on the shaft so I wouldn't damage the threads.
   / MF GC2310 steering motor bushings #5
Glad you figured it out and thanks for letting us know!!
Bus (A50323)
Bus (A50323)
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
