MF GC1720 4WD Front Axle Hydraulic Oil
   / MF GC1720 4WD Front Axle Hydraulic Oil #1
johnnylee1945
Liberty, Idaho
2018 MF GC1720
2018 MF GC1720-4WD...
A newbie here... Silly question, why would the Hyd. Oil in Front axle be dark colored after only 55 hours? I have been using 4WD to push snow since Dec. But it seems awfully dark...???:confused:
Thanks in Advance.
   / MF GC1720 4WD Front Axle Hydraulic Oil #2
Wouldn’t be hydraulic oil in the axle; should be basically gear oil I would think. Check your manual for the specs
   / MF GC1720 4WD Front Axle Hydraulic Oil #3
It's hydraulic oil...
Mine was kinda dark too. Who knows why.
Didn't worry about it and put new in. Still going strong.
Thanks seville009 , but it is hydraulic oil, same as the transmission and rear end (hydrostatic).
Snobdds, I guess that is about it... I did the same. Put new end and will not worry. Thanks!
   / MF GC1720 4WD Front Axle Hydraulic Oil #6
Probably dark from all the cutting oil at the factory. That is why they typically recommend changing all the fluids at 50 hours....flush everything out.
   / MF GC1720 4WD Front Axle Hydraulic Oil #7
My 2009 GC2410 called for MF Permatran lll for the front axle, but I decided to use this:
AMSOIL SYNTHETIC GEAR LUBE SAE 80W-90
KC
   / MF GC1720 4WD Front Axle Hydraulic Oil #8
The front end lives an easy life from a lubrication stand point. If you are in a cold climate lean toward the hydraulic oil and in warmer climates the gear oil is probably fine. The oil in the front end of a tractor is a non issue.
2021 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2021 SMITH...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
