MF GC1710 RPM
   / MF GC1710 RPM #1
Langanobob
Reno, NV
AC HD6G, Ancient Kubota HK5 Mini Excavator, MF GC1720
I understand that the GC1710 reaches its rated HP at 2600 RPM. Is there a rev limiter that keeps the RPM at 2600 max, or can you go above 2600?
Thanks!
   / MF GC1710 RPM #2
My 1715 goes over 2600 no problem
   / MF GC1710 RPM
Thanks!
   / MF GC1710 RPM #4
The GC1705 and 1710 are governed at 2700. The GC1715 and 1720 are set at 3000. Same motor in every way. That's how they get the horse power difference.
   / MF GC1710 RPM
I've heard several different stories on this. Some people say that the GC1715 and GC1720 also have fuel injection pumps with slightly more capacity. Who knows? Maybe we'd have to get to know an engineer in Japan to really find out for sure.
If it's just the governor setting I'm surprised no one's figure out how to hack it. Or maybe they have and are keeping it to themselves.
   / MF GC1710 RPM #6
Same engine, it's just the injector pump is governed to push more fuel, slightly.
A diesel engine runs on three things; air, fuel and compression. The air and compression are the same, that leave fuel. The 1715 and 1720 get slightly more fuel to get the extra horsepower.
A 1705 and 1710 can be made to equal the 1715 and 1720 with turning up the fuel and adding a shim for timing.
   / MF GC1710 RPM #7
In this case they can essentially get more fuel by increasing the max rpm.
   / MF GC1710 RPM
Snobdds, have you done this modification to your GC1710? How do you turn up the fuel? Is it as simple as turning a screw? BTW, thanks for the USFS road construction and maintenance handbook link in the Driveway Sinking thread.
   / MF GC1710 RPM #9
That is one way to get it, but by turning up the fuel you get more Hp/Tq at all levels of the power curve.
   / MF GC1710 RPM #10
I have not done it, but have looked into it. You need to update to the 1715/20 governor stop, which is slightly smaller. The hard part is putting in the correct shim on the injector pump to match the increase in fuel flow, as there are 13 thickness to choose from. I talked with a few injector pump guys and they told me I would need to send it in to set the injector timing with the correct shim. So because of that, I have not done it yet.
That USFS road book is the best I've seen about the proper way to build a road.
Massey Ferguson
GC1705 / GC1710 / GC1715 / GC1720 COMPACT TRACTORS 79035668
GOVERNOR STOP Page 01-0027
Item Part Number Qty Description
Comments Technical Specification
Add to Pick List 1 6254744M91 1 ADAPTOR/ ASSY, 320X080
GC1705/GC1710
PRIOR TO S/N DJH70201
PRIOR TO S/N DJH80204
Add to Pick List 7066768M91 1 ADAPTER 320MM X 65MM
GC1705/GC1710
AFTER S/N DJH70200
AFTER S/N DJH80203
Add to Pick List 4266251M91 1 ADAPTER
GC1715/GC1720
PRIOR TO S/N DJH90201
PRIOR TO S/N DJH00206
Add to Pick List 7066769M91 1 ADAPTER 250MM X 65MM
GC1715/GC1720
AFTER S/N DJH90200
AFTER S/N DJH00206
Add to Pick List 2 3710396M4 1 TENSION ARM
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
EZ Flow Gravity Wagon (A50774)
EZ Flow Gravity...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
Swict 84" Bucket (A50121)
Swict 84" Bucket...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
Suzuki King Quad ATV (A50515)
Suzuki King Quad...
