MF 880 plow help
/ MF 880 plow help #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I recently bought a MF880 plow and it has a hydraulic reset system. What I am wondering is how the system works. I have the operators manual but it is like reading greek for me. The manual said it is designed to work with the MF tractors at the time but would it work with a Ford 7710-2?
The manual states that system requires the tractor to have a constant pressure-type hydraulic system with at least 2000 psi pressure rating. Again, this is all greek to me.
Does anyone have any ideas or know what type of system the 7710 has? Thanks
/ MF 880 plow help #2
Just from what you wrote, it sounds like you have to have a closed center hydraulic system. I am not familiar with that plow model. Is your 7710 a open or closed system?
/ MF 880 plow help
I posted this message on three sites. On the Ag talk site I have learned thanks to RickB that the 7710 is basically both. It is an open centered system with closed centered remotes if that makes any sense to you then you are much farther ahead then I am. I am posting a picture that I guess is an accumulator that is on the plow. It is a poor picture but the only one I have until morning if it helps people understand better.
I will admit, I do wish I had just waited and found a spring reset as I didn't realize the hydraulic resets were so much fun.
/ MF 880 plow help #4
Your tractor has an open center system then. A closed center valve can be used as the end valve only in an open system. I would say to pressurizes the system on the plow and then use it to see if it will work that way. If it then trips, you will then need to pressurize it again. I can't guarantee that it will work that way, but I think that it will if it has a inlet check valve.
/ MF 880 plow help #5
1105, 1135, 1155 had a radial closed center hydraulic pump mounted in front of the engine simular to JD at the time. It had a open center charge pump in the rear end that charge the pump.
Chuck
/ MF 880 plow help
From what I have learned on the other board is that I could use this plow without the accumulator but I would have to hit the remote and manually reset the bottom if it tripped. But with the accumulator it won't be a problem. The 7710 would not run the plow the way the MF tractors at the time would without having the accumulator.
Here is a link to the thread on the Ag talk board as I have learned quite a bit so far. Ag Talk
/ MF 880 plow help #8
I went and read the other site. I think the same thing as the last poster. Hook it up, pull your lever to put pressure to it then let off, if it trips pressurize it again.
/ MF 880 plow help #9
With the accumulator you can operate it; if there is any leakdown in the system it will be kinda a pain.
Might want to keep your eyes open for a non-hyd plow - trips are even better than the hyd extras. It was one of those ideas that looked good on paper to the engineers, and some even worked good when new. But then reality sets in, and they are sold for scrap.......
--->Paul
/ MF 880 plow help
I will see how this one works out but I am always keeping my eye out for equipment. If I can upgrade then I will. I didn't realize this plow would be so much fun when I bought it. I will see how it goes and hopefully I won't regret buying it.
2019 Caterpillar 289D (A64126)
2019 Caterpillar...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
John Deere 4040 Tractor (A64047)
John Deere 4040...
