MF 65 Loader Hydraulics
   / MF 65 Loader Hydraulics #1
tkelly0224
Bow,nh
M101A2
Hey Guys,
I'm new to the boards here. I'm about to get my first tractor, my father in law is going to let me use his early 60's MF 65 indefinitely. He's owned it since 1980 and it has been a solid reliable workhorse for the past 36 years. It is a gas engine with a loader. I'd like to improve the loader, it uses the internal hydraulic pump and it is slower than death compared to his new tractor. I'd like to avoid using the rear PTO shaft as we have a bunch of implements that require the PTO. What other solutions have you guys seen or used? I understand that it will never be the new tractor, but I would like it to take less than a minute and a half to dump the bucket.
Thanks,
Todd
   / MF 65 Loader Hydraulics #2
You can get an adapter, maybe Ebay, that hooks to the front crank pulley and run and extra hyd pump from it. If you look up under the front end you will see a hole where the shaft goes through.
Rich
   / MF 65 Loader Hydraulics #3
My diesel MF 65 was set up that way. It made it near impossible to change the fan belt tho. I suppose that I could've pulled the radiator.. but I didn't.
Thanks for the replies, I've been seeing alot of comments about the steering arm hitting. What is everybody doing to prevent this?
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
