MF 65 Hyd
   / MF 65 Hyd #1
sitn
Osyka, MS.
MF 65, Farmall Cub, JD 450B
Greetings, As a new member of the thread, I outside of Osyka, MS. and have three tractors. MF 65, Farmall Cub and a JD 450B. I have a question for the MF65. Just recently installed a remote valve selector on top of the transmission case and ran two hoses to the dual spool valve to operate a dual tandem disk. Problem is this. No lifting of the disk. The PTO does work because I use my bush hog. The three point hitch works also. The valve body has six ports, two for fluid in and out. Two upper and two lower ports. Exactly which ports do I use to go to the hyd cylinder on the disk?
sitn
   / MF 65 Hyd
Thanks. This new for me to navigate through. Have to get used to the way things are done. Harder than some other sites I belong to.
   / MF 65 Hyd
Nice looking rig you have there. I finally got my remote cylinder to work, except one of the tie rod bolts on the cylinder broke. Replaced two and then the o'ring seals blew out on the clevis end. What a day.
   / MF 65 Hyd #7
Welcome to TractorByNet!
I moved your thread to the Massey Ferguson Owning & Operating forum. :)
New Holland 1431 Discbine (A50515)
New Holland 1431...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Bus (A50323)
Bus (A50323)
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A51039)
Rhino FS15...
